7 members (NJC, F100Ranger, jal12147, Hotrod Lincoln, Bill Hanlon, Peggy M, Otto Skorzeny), 90 guests, and 4 robots.
Topics128,087
Posts1,056,337
Members48,442
I
Junior Member
Junior Member
I Offline
South Africa calling!
Hello!
I found a 1960 suburban (jet pod lights) but sadly the windshield has discoloured (black/yellow) from 20 year old sun damage. Is there any way I can get this off or must I source a used windshield? If so, which model windshield will fit? An Apache(twin headlights) a 1957 pick up (single headlights) or a 1962 pick Up Fleetside? The 2 doors on this 1960 pick up are similar to an Apache but the front has a square hood like the Fleetmaster. Hopefully someone can assist with this info. Many thanks. Piers Fitz Gerald (Cape Town) email: [email protected]
ingrid fitz gerald
Ingrid - the terminology is a bit confusing, but the 55-57 + the 58-9 dual headlight ["Apache"] are one series of cab that has a unique winshield - the 60-63 series cab has a different windshield, tho similar, and the 60-61 had dual headlights too, dropped in 62 - the 64 up series doesn't have the 'dogleg', so different windshield - the 60-66 series trucks were called "Apache" too, but that name just means 'light duty truck'
so, for a 60 you need a windshield from a 60-63, and there's nothing you can doo about that 'fogging', it's between laminations, and happens to all of them sooner or later - not sure about waaaay over there, but the winshields are available here new
A South African 1960 model may not be the same as a US '60 model. Go to the "Gallery" section of this site and look at 1960 models then tell us if it looks the same.
And while you're at it, send a picture of yours to the gallery.
previous post There's lot's of information out here, pictures would help. grin .......g
I
Junior Member
Junior Member
I Offline
Thanks everyone for your kind replies.Picture on the way to the Gallery (African time!)
ingrid fitz gerald
Okie dokie folks. Here are the panel pictures. See if you can help.
(I'm working on two gallery pages for Ingrid. One for his '35 and then this '60). But until then, we can move on this.)
front
side
rear
Peg
~ One of many.
Ingrid after looking at the pics,windshields out of any 60 thru 63 10 thru 60 series trucks would fit,be it a panel pickup sub or cab and chassis ;)steve sr. p.s. you might ask how iknow, because we once took a 63 6500 gmc tractor that was being scrapped out and put the w shield into my buddie,s 60 chevy apache 30 wrecker.
k10 Offline
You can purchase new tinted and tinted shaded windshields, but the clear original type windshields are not currently being reproduced.
