| | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 5 Junior Member | | Junior Member Joined: Jun 2005 Posts: 5 | South Africa calling! Hello! I found a 1960 suburban (jet pod lights) but sadly the windshield has discoloured (black/yellow) from 20 year old sun damage. Is there any way I can get this off or must I source a used windshield? If so, which model windshield will fit? An Apache(twin headlights) a 1957 pick up (single headlights) or a 1962 pick Up Fleetside? The 2 doors on this 1960 pick up are similar to an Apache but the front has a square hood like the Fleetmaster. Hopefully someone can assist with this info. Many thanks. Piers Fitz Gerald (Cape Town) email: [email protected]
ingrid fitz gerald
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ingrid - the terminology is a bit confusing, but the 55-57 + the 58-9 dual headlight ["Apache"] are one series of cab that has a unique winshield - the 60-63 series cab has a different windshield, tho similar, and the 60-61 had dual headlights too, dropped in 62 - the 64 up series doesn't have the 'dogleg', so different windshield - the 60-66 series trucks were called "Apache" too, but that name just means 'light duty truck'
so, for a 60 you need a windshield from a 60-63, and there's nothing you can doo about that 'fogging', it's between laminations, and happens to all of them sooner or later - not sure about waaaay over there, but the winshields are available here new
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A South African 1960 model may not be the same as a US '60 model. Go to the "Gallery" section of this site and look at 1960 models then tell us if it looks the same. And while you're at it, send a picture of yours to the gallery. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | previous post There's lot's of information out here, pictures would help.  .......g | | | | | Joined: Jun 2005 Posts: 5 Junior Member | | Junior Member Joined: Jun 2005 Posts: 5 | South Africa calling!
Thanks everyone for your kind replies.Picture on the way to the Gallery (African time!)
ingrid fitz gerald
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Okie dokie folks. Here are the panel pictures. See if you can help. (I'm working on two gallery pages for Ingrid. One for his '35 and then this '60). But until then, we can move on this.) front side rear Peg
~ One of many.
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Ingrid after looking at the pics,windshields out of any 60 thru 63 10 thru 60 series trucks would fit,be it a panel pickup sub or cab and chassis ;)steve sr. p.s. you might ask how iknow, because we once took a 63 6500 gmc tractor that was being scrapped out and put the w shield into my buddie,s 60 chevy apache 30 wrecker. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You can purchase new tinted and tinted shaded windshields, but the clear original type windshields are not currently being reproduced. | | |
