2 members (2-Ton, Bill Hanlon), 82 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
#24389 07/15/2002 5:27 AM
Fox
Offline
Has anybody used or know someone who has used a 12 bolt Gm rear in a AD truck.(1950) I hope to put posi in it, all the good stuff. What are the dimensions, will it fit my truck, what vehicle can it be found in? As for rims they're not going to be too crazy. I'd like to keep a Chev a Chev. Any help will be greatly appreciated. Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
#24390 07/15/2002 6:31 AM
Camaro Rears are pleantiful and strong. Posi Units are available. Look for between 60 and 62 inches drum to drum (caliper to caliper)
Ed
#24391 07/15/2002 11:25 AM
a 10 bolt 8.5" would be fine also. Nova is another source
#24392 07/18/2002 1:51 AM
Gotta watch those Novas though, some of them were really narrow. I have one and I have to get some silly offset wheels to get the tires in the right place.
As for 12 bolts, you can find them in any late 60's SS version Gm muscle car; Impalas, Chevelles, Camaros, etc. Novas from the 70's had 'em too.
You don't really need a 12 bolt under your truck unless you plan to do some real drag racing or put sill ypower to the ground. My 52 is so light in the rear I can light the tires anytime I want to. This is hard on tires but not too taxing on the rear end! grin
'52 Chevrolet 3100 (Rodded of Course)
'97 Eagle Talon TSi(Turbo Baby!)
#24393 07/25/2002 9:55 PM
I ran a 1964/65 truck 12-bolt truck rear end (they are different from the car 12-bolt) in my '54 3100 for about 10 years when I switched over to an open driveline. I had to take off the coil spring stuff, weld on the leaf spring pad, and have a drive shaft from a newer truck shortned, but the rear end fit just fine. I don't remember the measurements, but there was no discernable difference in looks.
1954 Chevy 3100
454, T-400, GM 14-Bolt Disc brake
Monte Carlo Front Clip
