5 members (artinva, Rich'sToys, Shaffer's1950, Chip O, JakeM), 116 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
Junior Member
Junior Member
ok guys -brake question....i need to know what lenght brake line for the brake line that runs thur the raditor support and to both front brake cyd's.......i replaced the master cyd, all wheel cyd's and last Oct. this line started leaking fluid unde the raditor......it's spring and i want to ride in "My Panel".....can i just buy a straight brake line locally and bend to suit my needs....i thought some of you have fixed this one before and give me some idea's ansd length of line needed------THANKS FOR ALL REPLIES
1950 Chevy Panel 310
Your best bet is to pull the old one out, measure it, and use it as a template to bend the new one. I'm sure the parts vendors carry that line, if you don't want to worry about bending and flaring your own.
1954 GMC De Luxe COE
I don't think there is a brake line running under the raditor on a stock 1950 Chev or GMC.
I'm absolutely certain there is not on a '54 or '55 1st.
On the stock truck there are two lines coming off the master cylinder. One of them goes only to the left front. The other crosses under the bellhousing to a tee fitting. One line goes forward from the tee for the right front, the other goes to the rear where it terminates in a flexible line that goes to the rear axle.
Are you sure you have a brake line running under the radiator?
Junior Member
Junior Member
i will double check on the brake line under the raditor......it is enclosed under there somewhere. i was going out for a ride last fall and i hit the brakes and it went to the floor, i got out parked it, and fluid was coming out under the raditor......so it still sits......i still start it weekly and drive around the yard( 5 acres) in double low.....with no brakes....i will check today!!!!!it;s going to be spring soon and i wanting to ride around in my Panel..all original except for chrome baby moon wheels and white letter tires.
Junior Member
Junior Member
Finally getting around to the brake repair......i removed the rubber brake lines from both front wheel cyl's, now i need to know what length brake line do i need to buy to bend....and to get these brakes working again..i guessing it only runs from one front wheel cyl to the other front wheel cyl??????( i have a back injury from a fall @work last dec...making it real hard to see what's what under there)...thanks for all replies!!!!!!
Your FLAPS may have 25 foot coils of steel brake line, if not they can get it for you or Jegs, etc.. I think it's 1/4 inch for your truck. Then remove the original, drain old fluid out for proper disposal. SAVE ALL ORIGINAL FITTINGS! I like to make a bending table with a thick piece of plywood and a couple sawhorses. Carefully copy the original, leaving a few inches extra at each end. Then cut end square, ream inside tube, file burr on end a little, and use a 45 degree double flaring tool to make a practice flare on the excess end, putting the old nut on first. This excess for the learning curve as this really takes a little practice to get down. Dunking the end in fluid seems to help the forming a little. Check the end to make sure you are getting nice round double flares that do not mushroom off center.
Also mind how much extra tube is needed for the flaring before making the "money cut." Repeat for other end and you are on the way....
Forgot to mention, a good tube bender really helps bend that steel tube. Imperial or rigid are great, cheaper ones may also work, maybe not so great...
Quote
One line runs from the driver's side wheel cylinder to the master cylinder. The passenger side runs from the wheel cylinder to a tee that is located on the passenger side just behind the bellhousing crossmember.
From that tee, one line runs to the rear axle and another runs to the master cylinder.
You can buy pre-bent sets that might be easier for a guy with a bad back to install...
