1 members (DaveV),
96
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Hello all...
I am new to this forum. My son and I are working on a 57 Chevy 3105 Panel. We bought it as a started "frame off" It has no drive train, springs, or axles, and no steering column. We are considering looking for a later model donor vehicle that we could put the body on. I know the wheelbase is 114" but I cannot find a spec for the width. Can anyone enlighten me?
Also, can anyone recommend the "Ideal" donor vehicle make and model?
Keep in mind that we would like to have "modern" suspension.
Thanks, | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Thanks for the link...
Very helpful | | | | | Joined: Mar 2005 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 32 | Inky, I have a 57 Suburban thats all original. The rear measures 60 inches from wheel mounting surface to surface. I too am looking for an upgraded rear for mine. The s-10 is too narrow from what I can tell its 54 in. I have a 69 Camaro and its rear and its exactly the same dimensions(60 in.) I know this doesn't solve the donor vehicle idea but I think it will be hard to find one thats perfect. I'm looking into an IFS front to go with the rear instead of the donor idea. Hope this helps. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Problem solved... or started???
We picked up a 77 Blazer that we plan to put the 57 body on. I know it will be alot of work, but it will be a great experience. Any suggestions (from experience) would be appreciated. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Those K5 axles are probably going to stick out past the fenders. There are ways around it if you're creative. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Just how creative will I have to be? | | |
