1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#243726 10/07/2004 3:20 PM
Here's a clean Suburban found on eBay. It would be a great start for some stovebolter. They only seem to appear when I'm broke frown
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2492422869&rd=1&sspagename=STRK%3AMEWA%3AIT
#243727 10/07/2004 6:23 PM
Moderator
Moderator
That's more than just a dent in the hood. Looks like it's split wide open!
Are those taillights stock? I kinda like 'em and I need to do something different with the taillights on my panel.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#243728 10/07/2004 8:14 PM
The tail lights were an options and are the same as from a 39 sedan.
Fiberglass repos are available, and they also come up on ebay once in a while for $100 or so...
Mounting instructions are in the AD Assembly Manual.
Jim
Jim
#243729 10/07/2004 8:15 PM
Quote
They look right. '39 Chevy car taillights are what you should find on one of these. Neither of my Suburbans have those lights though.
#243731 10/07/2004 10:30 PM
Moderator
Moderator
Anybody know a vendor on those taillights?
Burma-Shave (1947)
#243732 10/08/2004 12:29 AM
If someone is re-poping those tail lights I've not identified them yet. I've been watching eBay and swap meets. On eBay they always seem to go for more than I'm willing to pay. I saw a set at a swap meet last spring for only $70, but it was late in the day, and I'd spent all my money already...
I'm still looking!
#243733 10/08/2004 12:43 AM
k10 Offline
#243734 10/08/2004 2:33 AM
Those '47.5-'55.5 dual tail/brake lamps for panel/suburban/canopy bodies were a factory option (#249) and are hard to find. These were required equipment in some states at least as early as 1950 (in WA, at least).
In 1954, there was an accessory turn-signal set that came with the housing-cup/switch/knob for mounting under the steering wheel and a wiring harness for tail/stop/signal lamps (also came with wiring and dual-filament bulb holders for the front parking lamps).
Chev's of the 40's used to sell the body-mounting gasket/seal for the dual tail/brake lamp, and also the chrome rings for the lenses and the gasket/seal for the chrome lens ring. As stated above, there does not seem to be a reproduction for the housing but the units show up every so often on eBay.
I was lucky and found a complete NOS 1954 Suburban set in Hemmings in 1997 (complete with fold-out 12-page installation drawings and instructions).
Here are photos from the side and rear, and of the switch-arm (1954).
Tim
1954 Suburban rear signal lamp - from the rear
1954 Suburban rear signal lamp - from the side
1954 Suburban rear signal switch under the steering wheel.
#243735 10/08/2004 3:04 AM
Yeah Tim those are the lights I want...
My '55 1st 3100 has the steering column with the turn signal switch. I don't want the column but would love to have those lights!
#243736 10/09/2004 12:11 AM
Tim--
Thanks for showing piks of that turn indicator--I've seen bits and pieces of that assembly but never the whole assembly. Do you know if the cars had them and if so will those fit the burb/truck column?
Buzz'n Half Dozen
#243737 10/09/2004 5:05 AM
A third one can be mounted above the doors for a high-mount brake light. GM gave the directions in a '48 tech service bulletin - Jim Carter has a copy on his web site.
I found a '38 (I think) Olds tailight on eBay with a cool fin on top. It uses the same lens and retainer as the '39 Chevy. Combined with a rusty '39 Chevy housing (for the indented bottom), I should have a cool roof-mounted taillight.
1954 GMC De Luxe COE
#243738 10/09/2004 5:56 PM
Here is a link for a lamp assembly similar to what you are looking for. The index number G-8 http://www.wescottsauto.com/site2003C/g_lights_indx.html You just need to fabricate a mounting bracket. I will post back when I find a supplier for the factory tail lamps.
#243739 10/10/2004 3:00 AM
Moderator
Moderator
Yeah, Krissly, those are lookin' good. doesn't give measurements on 'em, though frown
I see the G9s on the next page look something like the taillights protruding from the rear doors of the other panel.
Burma-Shave (1947)
#243740 10/14/2004 3:10 AM
I called the factory on these lights. They measure 5-1/2" long and 3" across the end at the lens. They are for a 1937 Ford. The difference between these and the 1939 Chevy lens is the mounting surface. The Chevy is a little smaller and has a flat spot at the mounting surface. It wouldn't be hard to flatten a spot on the 37 Fords if one wanted to use them. I also found 2 used sets of 1939 Chevy assemblies. They are in super condition and bring a super price, $200.00 eek
