6 members (Jays58, tricordati, Gazz, KEVINSKI, JW51, Shade Baby), 141 guests, and 3 robots.
Topics128,095
Posts1,056,468
Members48,444
OK, like the subject says, after about 1.5-2 miles of driving the engine starts sputtering and eventually dies out. I verified that I'm getting fuel through the line to the carb by pulling the fuel line and pressing the starter and get lots of fuel shooting through. I'm wondering if I'm either getting a gas buildup in the carb or if maybe the accelerator pump is sticking. It's a 1952 235 with a Rochester B carb. I have another carb to try and swap in but haven't done it yet, do you think I'm on the right track or do you have other suggestions?
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
Big Bolt Shop Curmudgeon
You didn't say what happens after the engine dies. Will it immediately restart? Does the engine have to cool down?
Let me pose some questions:
When the engine dies, will it immediately restart and if so, does it start easily?
If it won't start immediately and you let it cool down a bit (10 minutes), will it then restart immediately?
On restarting, does the engine immediately idle and run smooth, or do you have to open the throttle (mash the accelerator to the floor) to keep it running?
Any backfiring?
If it won't restart easily, how long do you have to crank on it to get it to fire and run?
Glenn
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
Red dot, center of chest ...
I can think of two things:
1) Choke is stuck or air intake is restricted somehow
2) Heat-related electrical breakdown - like the coil is breaking down when the motor gets hot
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Mb,,,check what Glenn and Baldeagle mentioned(they are like hounds on a blood-trail so far grin )
Let us know how it works out. smile
Well, it will restart once (maybe twice) after it dies but is very hard to keep running, have to use the choke/feather the throttle to keep it running. After it dies for good, about 10-15 minutes later (cool down time) it will start and run and idle nice until it heats up again, then same symptoms as described before. No backfiring during any of this, just alot of bucking and spitting, that's what made me think of fuel problem somewhere, but I guess it could be electrical too. I guess I could just swap out the carb on spec and see if that fixes it, if not, I do have a spare coil too that I could try in there.
Keep it coming guys,
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
Sounds like a coil or condenser breaking down under load. In my experience, when a condensor breaks down, it will cause erractic spark timing, which leads to the backfire in carb. A bad coil is easy to spot in some cases. Drive the truck till it dies and go outside and touch the coil casing. (be careful grin ) If it is hot to the touch, and I mean hotter than the engine, then it is most likely shorted.
Personally, I'd change the condensor first,it's easy and cheap. Sure doesnt sound like fuel problem
