8 members (mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, homer52, 1 invisible), 102 guests, and 5 robots.
Topics128,089
Posts1,056,137
Members48,435
#243232 03/27/2005 7:31 PM
Hey all. Spring is almost here like a double edged sword.
Warm enough to get outside and work on the truck.
Need to move the truck out of the space it was in all winter.
Here's my problem. Front tires went flat. I put it up on blocks to have access under the beast and pulled the wheels to send around the area with friends to see if they could find 16" substitutions for the stock 17"s. Now I need to move this thing in the next week or two.
I haven't been able to find any replacement wheels and I DONT want to dump cash into new 700x17 tires. I also don't want to keep the rear 17" split rims either. (they'll all be in the swap meet as soon as I can get replacements.)
Stockton wheel is willing to make a set of wheels with the correct back-spacing (3-3/4" right?) but they'll run $155 each and take 3-4 weeks.
www.stocktonwheel.com/light_truck_wheels.htm
Attractive option, because they have trim rings and moon caps and stuff to fit the "20 series" wheels. Pricy and Slow tho. Hate to order 4 custom wheels and then find they don't work for some reason or other and be in the same mess, and poor, four weeks from now.
Just wanted to know what you guys would do in my situation?
Help... Time's tickin'
-joel
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
Put new tubes in your old tires and move it?
Ok. Smarty-britches. You got me.
Don't you hate it when the stupid, simple, obvious choice slips under the radar because you're so intent on a different solution?
Great. So I can get out of my wife's shop and into the parking lot for a couple weeks. So how 'bout the other half of the question... Has anyone used Stockton Wheels? Thanks to Baldy I'll have the time to wait for their wheels. Any reason those wouldn't work for me?
Here's my latest plan.
4 Stockton 16x7 "20 series" wheels with 3-3/4" back-spacing. (same wheels should work front and back on a '52 3800 panel right?)
4 215/85/16 tires
Any specific questions I should ask when ordering? Pitfalls? Unless someone on this forum tells me otherwise or has a better suggestion, I'll place the order early this week.
Hope everyone had a nice Easter.
Baldy, I'd send you a chocolate bunny if I could.
-J
'52 3800 Panel
-Groucho Marx
A guy on another forum I participate in just used Stockton Wheel to have 16" rims put on his 8-lug centers and was very happy with them.
I hope he doesn't mind me putting it here:
Quote
Stockton Wheel in Stockton, California just returned my rims. I sent 5 eight lug split rims to them where they removed my original centers, then welded on new 16" tubeless rims so I could run 16" radials. The choices in 15" radials for my truck were not that great and the profiles all looked too bulbous for me; I wanted the original look and found that I could best accomplish that with the 16" vintage radials from Diamond Back.
I dealt with Rob at Stockton Wheel and they did a great job. It took longer than expected but that was due to Stockton waiting for the custom outer rims to be manufactured by their supplier. Good outfit who knows their stuff and has been in business for over 100 years I think.
