| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | 2 questions Do the "rollers" that run on the window channel actually roll or do they just slide in the groove in the bottom of the channel. Looks to me like they slide.
I'm thinking of using door window channel for the rear windows in my burb. ('46)The door channel is not long enough to go the length of the glass but there is plenty of room for the roller travel. Do you think this will work? The glass will stick out beyond the channel about 2 or 3 inches. Door window channel is available but the rears are not. thanks Jim | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Jim - I can't help you with the rear windows, but you are right about the "rollers" they don't roll. Just put some white grease in that lower track and let'em slide. george | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | that's what I thought. I think I'm gonna try that shorter window channel. I really think it will work. The trouble is it's gonna cost me about $250 for the tracks even if they don't work. I think I'm like most - I don't mind spending money but I don't like wasting it! Jim | | |
