| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I am running a pre 1960 283 in my 49 sub. Using the short water pump. Having a problem finding brackets for a power steering pump and alternator. The 283 has no drilled and tapped holes in the front of the heads for brackets. There are 4 tapped holes lower down on the front of the block. I have seen early 60s engines with the power steering pump integral on the back of the generator as one unit but I would rather run the alternator. Are brackets available? I have checked a couple of local boneyards with no luck. Can any of you Bolters that have been through this offer any advice? Most of the catalogs have lots of brackets but how do I know what to order? Weeds | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | When I'm setting up power steering, a/c and alternator in chevy small blocks with fulie heads or power pack heads with no bolt holes in the heads, I order my brackets from Alan Grove Components. http://www.alangrovecomponents.com/
Joe
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think alternators started being used in '63 or '64 and the bosses in the front of the heads started maybe '68? I'm not sure the exact years, but it was something like those...
Finding anything from those years in a wrecking yard will be a challenge!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Chevy1 thanks for the reply. Used your link to Alan Grove. It looks like he has all the brackets and pulleys I need although I will probably call him to find out what I need to order.
Weeds | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Old Sub. Thanks for the info. Its back to the junkyards.
Weeds | | |
