4 members (Oswald, Peggy M, 2-Ton, Hanks custodian), 364 guests, and 2 robots.
Topics128,160
Posts1,057,050
Members48,463
#243018 11/14/2004 5:33 AM
Finally removed and cleaned the instrument cluster and bezel. There was a ton of black overspray.
[img]http://hesproductions.com/59sub/images/1st_fam_outing/images/instrument.jpg[/img]
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#243019 11/14/2004 6:44 PM
Thought my cluster was a lost cause 'till I cleaned it. I painted the back panel with semi-gloss black. The numbers on the '66 are on the clear face plate. I compounded that, and, painted the bezel. The thing looks new!! I also cleaned the mounting screws. They were all corroded due to the dissimilar metal. Now the gas gauge works!! For any of you guys with gauge/grounding problems with your cluster, this is the first place to look. You know, where the bezel screws to the cluster. The ground is then supplied through the bezel to dash mounting points.
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#243020 11/16/2004 4:58 AM
Another nice job.
