| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Thought my cluster was a lost cause 'till I cleaned it. I painted the back panel with semi-gloss black. The numbers on the '66 are on the clear face plate. I compounded that, and, painted the bezel. The thing looks new!! I also cleaned the mounting screws. They were all corroded due to the dissimilar metal. Now the gas gauge works!! For any of you guys with gauge/grounding problems with your cluster, this is the first place to look. You know, where the bezel screws to the cluster. The ground is then supplied through the bezel to dash mounting points. | | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | | | |
