| | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 30 | hi all,
was there ever a 327 availiable in a 1966 chev 3/4 ton 4x4 from the factory?
thanks jordan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | According to the specs I have, no. The only V8 in the 4x4 models was the 283. I do beleive the 327 was used in the 2wd models, however.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 30 | i kinda figured that. the reason i ask is i found a '66 3/4 ton 4x4 and it says its got a 327 in it but he could have it listed wrong and it says that its 4x4 but when i looked in the cab i ididn't see a shifter for the t-case. btw its got a 4 speed manual in it, lower front fenders need to be replaced as do do the rockers. asking price is $5500. is it worth it?
thanks jordan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would suppose it would depend on the condition of the rest of the truck, 5500 might be a little high for an unrestored truck. Try seeing if he'll come down on the price, especialy since it's listed wrong.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 30 | as far as i know the rest of the truck is solid bu you only tell so much at 9:30 at night. we're going back to look at it on saturday afternoon. then we'll be able to really tell whats going on. if it does turn out to be mislisted i am going to see how far he'll go down on price. thanks for the prompt response to my question bill.
