| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Okay, eventually I am going to convert to front disc brakes with a five lug pattern to match the Nova rearend out back but since I have a lot of other places where the cash is going right now; What would it take to convert my original six lug drum front brakes to a five lug pattern drum brake? The truck is a 1952 half ton.
Thanks for all replies, Wayne | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Late 50's car hubs/drums are 5 lug and should work.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | | | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Okay, Dumb question; Is the hub like the spindle? I figured on at least the drum. Does the hub include bearings etc?
Sorry for the dumb question?
Thanks, Wayne | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Thats how ya learn,,asking questions. The hub is the center part that goes over the spindle. It contains the bearings and inner grease seal. The drum fits over the hub,,usually held on by a couple rivets. The spindle is the "axle" that all this mess slips over,,held on by the spindle nut and cotter pin. Marty | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Swapping those early car drums onto your truck is relatively simple and if you have the bearings from both you'll be able to work out exactly which inner and outer bearings you need, its some combination of the two different stock sets.
I'd caution that paying much for the 5-lug drums plus doing a good brake job might mean you are spending as much as the disk conversion would cost.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I just did that myself.I picked up a pair of hubs and bearings ,complete off a 51-54 chev car.They use the identical inner and outer bearings(that gives me spare bearings). I paid $15.00 for the pair.Previous to that a friend of mine gave me complete 57 chev car backing plates,brakes,springs cylinders and hubs with drums ,,all new for free.I used the brake shoes and drums and spring kit. The hubs and wheel cylinders wouldn't fit.Apparently the drums are the same for many different applications but the hubs you need are 51-54.. Lothar | | |
