2 members (Joe H, Naturalthud), 196 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#242852 10/25/2007 8:58 PM
Z
ZB3
Offline
Z Offline
Okay, eventually I am going to convert to front disc brakes with a five lug pattern to match the Nova rearend out back but since I have a lot of other places where the cash is going right now; What would it take to convert my original six lug drum front brakes to a five lug pattern drum brake? The truck is a 1952 half ton.
Thanks for all replies, Wayne
Late 50's car hubs/drums are 5 lug and should work.
You Tube
'52 car hubs and drums
Z
ZB3
Offline
Z Offline
Okay, Dumb question; Is the hub like the spindle? I figured on at least the drum. Does the hub include bearings etc?
Sorry for the dumb question?
Thanks, Wayne
Thats how ya learn,,asking questions.
The hub is the center part that goes over the spindle. It contains the bearings and inner grease seal.
The drum fits over the hub,,usually held on by a couple rivets.
The spindle is the "axle" that all this mess slips over,,held on by the spindle nut and cotter pin.
Marty
Swapping those early car drums onto your truck is relatively simple and if you have the bearings from both you'll be able to work out exactly which inner and outer bearings you need, its some combination of the two different stock sets.
I'd caution that paying much for the 5-lug drums plus doing a good brake job might mean you are spending as much as the disk conversion would cost.
I just did that myself.I picked up a pair of hubs and bearings ,complete off a 51-54 chev car.They use the identical inner and outer bearings(that gives me spare bearings). I paid $15.00 for the pair.Previous to that a friend of mine gave me complete 57 chev car backing plates,brakes,springs cylinders and hubs with drums ,,all new for free.I used the brake shoes and drums and spring kit. The hubs and wheel cylinders wouldn't fit.Apparently the drums are the same for many different applications but the hubs you need are 51-54..
Lothar
