2 members (66flea, 1955 1 Series), 98 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
HI.... the VIN number on my door plate is H540009985...so what I understand from the decoder is that the truck was built in H=Fremont,CA in 1954 and it was the 9,985 truck built at that plant...would this be correct? I was told that this number was for a 1950 Oakland, CA model? We thank you for your time and effort on this one in advance. T/C Steve ohwell :confused: frown
I'll bet that the 4th digit is actually an "O" instead of a zero. It breaks down like this, H= 3100, 54= model year, O= oakland, CA assembly plant, 009985= sequential production #, usually starting with 001001.
Bill Burmeister
Bill... It's no wonder your mom called you son you are so bright! Thanks for the code work. It is now part of my information packet about our truck. T/C Steve
HMMMM,,Both my '54s have the "H54000,,ETC...
But the "o"s look just like the zero's. ??
Or the zero's look just like the o's. ??
Marty
I am not sure why you thought your truck was built in Fremont, but in 1954 the plant was still in Oakland, the Fremont plant did not open until 1964. Now they make Toyotas there.
