1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#242506 10/18/2007 2:33 PM
Has anyone done repairs on speedos for these 1/2T's? I have 2 with bad odometers. The 100's work but will not turn over to K's. Need new?
Where?
tks
#242507 10/18/2007 2:53 PM
there's a broken plastic tab on the 100's wheel so it doesn't trip the next one - easiest to find another set of number wheels and change the whole thing [carefully] - I haven't seen them reproduced, but a speedo repair service might have something, and if you're determined, you might be able to swap the 100's wheel with the far left one [100k] where the tab isn't needed
also see this , and the complete speedo unit is the same 55-59
#242508 10/19/2007 2:35 PM
The complete instrument panels (used) are avaialble on eBay fairly often. Usually pretty cheap.
