1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | I have a LWB Fleetside 2WD. I need the aproximate weight to calculate the stall speed needed for an aftermarket torque convertor. I'm running a very HP 350 with a Turbo 350 auto. Vehicle weight is just part of the equasion. I've searched high and low for this info. Thanks! Eric
'64 C-10 Longbed Fleetside Custom with large window. BRE 383 stroker with Turbo 350.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i am not sure exactly my 64 c20 weighs 5000 lbs with a winch and me, i think the c10s weigh closer to 4000 lbs. never have weighed my 63 c10 but my 64 wrecker gets weighed all the time. hr | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | When I used to run my '66 C-10 LWB across the scales totally empty, I believe it would weigh about 3850.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | According to information in my GM restoration pack, a 1966 C-10 LWB Fleetside with standard equipment and unloaded weighs 3465. I would assume that a 1964 is about the same. | | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | Originally posted by Doug 57: According to information in my GM restoration pack, a 1966 C-10 LWB Fleetside with standard equipment and unloaded weighs 3465. I would assume that a 1964 is about the same. Wow! Thank you. Can anyone confirm this? Light is good! :p
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Doug 57 is pretty close, both of my C20s 63, and 68 are with in a couple hundred of the 3465. I've had them to the scrap yard and after I've dumped, that's about the number I get.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | Originally posted by LGriffin: Doug 57 is pretty close, both of my C20s 63, and 68 are with in a couple hundred of the 3465. I've had them to the scrap yard and after I've dumped, that's about the number I get.
Larry Great! Thanks. Eric
