4 members (Hotrod Lincoln, Ponchogl, Peggy M, 1 invisible), 81 guests, and 2 robots.
Topics128,057
Posts1,055,816
#242418 10/17/2007 8:12 AM
Apprentice
Apprentice
I have a LWB Fleetside 2WD. I need the aproximate weight to calculate the stall speed needed for an aftermarket torque convertor. I'm running a very HP 350 with a Turbo 350 auto. Vehicle weight is just part of the equasion. I've searched high and low for this info. Thanks!
Eric
'64 C-10 Longbed Fleetside Custom with large window. BRE 383 stroker with Turbo 350.
#242419 10/17/2007 11:16 PM
i am not sure exactly my 64 c20 weighs 5000 lbs with a winch and me, i think the c10s weigh closer to 4000 lbs. never have weighed my 63 c10 but my 64 wrecker gets weighed all the time. hr
#242420 10/18/2007 12:31 AM
When I used to run my '66 C-10 LWB across the scales totally empty, I believe it would weigh about 3850.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
#242421 10/18/2007 8:14 AM
Apprentice
Apprentice
Thanks a bunch guys!
#242422 10/20/2007 12:58 AM
According to information in my GM restoration pack, a 1966 C-10 LWB Fleetside with standard equipment and unloaded weighs 3465. I would assume that a 1964 is about the same.
#242423 10/20/2007 7:46 AM
Apprentice
Apprentice
Quote
Wow! Thank you. Can anyone confirm this? Light is good! :p
#242424 10/20/2007 3:36 PM
Doug 57 is pretty close, both of my C20s 63, and 68 are with in a couple hundred of the 3465. I've had them to the scrap yard and after I've dumped, that's about the number I get.
Larry
I don't own a vehicle that isn't old enough to drink.
#242425 10/20/2007 6:46 PM
Apprentice
Apprentice
Quote
Larry
Great! Thanks.
Eric
