| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Can someone tell me how much "pre-load" I should put on the tie rod/drag link ends? Just how much should the large slotted screw be tightened? I may go with the mordern ball joint tie rod ends....but I still need to know for the drag link. Thanks in advance!! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a link to the 48-52 manual that is online I would suggest you follow the procedure outlined in the manual. It is not very complicated it spells it out step-by-step. http://chevy.tocmp.com/1948_51truckshop/index.htm | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | WOW! Thanks......never saw this link. | | |
