5 members (78buckshot, Biermann, Otto Skorzeny, DadsFirstPickup, Charles in CA), 88 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
Can someone tell me how much "pre-load" I should put on the tie rod/drag link ends? Just how much should the large slotted screw be tightened?
I may go with the mordern ball joint tie rod ends....but I still need to know for the drag link.
Thanks in advance!!
Here is a link to the 48-52 manual that is online I would suggest you follow the procedure outlined in the manual. It is not very complicated it spells it out step-by-step.
http://chevy.tocmp.com/1948_51truckshop/index.htm
WOW! Thanks......never saw this link.
