| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Has anyone here used a Steering Damper on his or her straight axle stock AD? I’m not sure if it’s entirely the fault of the new Power Master bias ply tires or if there may be a little resonant oscillation at road speeds when I hit bumps in the road. This is not uncommon with solid beam axles with a long tie rod that can flex.
The complete front end was rebuilt with all new parts less than 1k miles ago and the steering has absolutely no play in it. Every thing that could be possibly wear was replaced. After mounting radials on the rear there was a noticeable difference on the ride. I’m looking forward to getting the radials on the front in the next week or two and hope the will further smooth out the ride.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I used one from a jeep and it seems to work well. It has been on the truck for about a year and a half or I would give you the numbers of the one I used. Can't remember now. But then again I have radials on all 4 corners and that could have an effect on how it steers. Tom | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I tried a steering damper on one & it was horrible. Downright dangerous. I,ve used them several times before with power steering & they woek great. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I'm a firm believer in the dampeners. Picked up a Universal kit at NAPA... had to fabricate my own bracket to mount it on the straight axle.
Have used them on all of my trucks and off-road vehicles and feel they are worth the money and install time. My front end is fairly tight and with the proper toe-in she runs straight as a bullet at a 70 mph cruise. I've got some pics in my Shoebox album that show the mount. Basically used a chunk of 3x3 angle iron and whittled it down to span the axle. No interference problems. Hope this helps.
Dave | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Dave, I'll keep NAPA in mind.
Boyd that's what my nephew put on his street legal Silver Crown car. It has a tube axle with a long tie rod and drag link just a little longer than the AD. The setup is very similar to our trucks. He had a shimmy problem after he put the car together and added a damper which stopped it. Said that one of the racers that he hangs around with gave it to him and that it was off of a VW bus, possably in the 80's sometime. Do you have any idea what year's will work? Denny Graham Sandwich, IL
| | | | | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hello all. Grant here. I recently switched rims with a more positive offset than stock, and came up with noticeable "bump steer" and wander. let me know how the stabilizer works. My alignment guy recommends using a dampener. Thanks, Grant. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't know about a VW damper, but I used a Moog SSD12 Trail Boss on mine, and it works very well.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Would that be a universal damper or for a specific application Bill? Tried looking at your webshots to see if you had a picture but my dialup is simply to slow and had to bail. I'll take that back, I found a few pics on page three, tks. Back in the days when I worked in as a counter man, most parts stores carried Moog products, I don't see the line at any of the flaps any more. Denny Graham Sandwich, IL ps. By the way, what is that humongous 1" thick Aluminum plate that the truck is sitting on in the picture???
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That VW idea sounds good. It won't be as stout as the universal ones. Carquest handles Moog under there own label. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Denny, I have been using a 'generic' steering damper on my truck for around 8 years. Running bias tires need all the help they can get. I feel that although a stabilizer is not intended to cure major underlying problems in steering, and I have done as much as I can to get the steering as correct as possible, the damper has made a positive difference in the stability of my truck. Stabilizer
1948 AD Pickup
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The SSD12 is a universal kit, mainly for older 4x4s, but will work on I beams, too. I'm lucky enough to have a flaps that carrys exlusevly Moog parts. I beleive that you're talking about my catch pan? in the pic, it's kind of misleading, because you can only really see the turned up edge. It's a home made pan, 1/8" thick aluminum.
