4 members (Tim Canfield, Oswald, Hotrod Lincoln, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#241989 10/08/2007 3:36 PM
Hey All,
I just swapped out my old 3-spd steering column for an automatic column I purchased from Stovebolter 4-5-6. Included with the shift lever was a small spring, a retention clip, and the shifter. I figured out the retention clip, how to get the shifter in the slot on the column, but am curious where EXACTLY the spring goes. Does it just slip over the nipple at the end of the shifter? Your knowledge is greatly appreciated.
#241990 10/08/2007 4:53 PM
Quote
Originally posted by olchevynut:
Hey All,
yes, it just sits on the end-I use white grease to keep it there while installing
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
