| | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I am trying to find out if these http://hudsonvalley.craigslist.org/pts/437433367.html will work on my 52 1 ton. I have been told that they should, but now I am seeing a thread to not go 16.5. Any thoughts on this? Thanks Steve | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Nice, Pacers based on your description there. I was wondering if standard chevy or ford ones would work, basically I want the truck about 3 in shorter than it is and that would be the easy way to go. Also the cheaper way too. | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | Hi,
IMHO, avoid 16.5 inch wheels, use 16 inch instead. No manufacturer sells vehicles with 16.5's anymore and replacement rubber can be up to twice as expensive as 16 inch. I am speaking from recent experience in this area.
Good luck.
Royzell | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'll second that. 16.5" tires are obsolete as far as current production goes, and the aftermarket has cut available sizes in 16.5 way back. The only current vehicle using that size rim is the Hummer H1, and the newer ones are starting to use 17s. Most 16.5s currently being made are the oversize off road mud tires. 16 or 17 would be a better option.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I guess I am still wondering about the rear axles and the wheels, just eyeballing it the other day I wonder if the 16" would fit on the Dually axle that is there. The brake drum seems much larger than 16". Is that just a back spacing issue that I can fix with spacers? Anyone do this before. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I'm running 17.5" wheels on my NAPCO. Try finding rubber for that size! Ouch. | | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Hotshoe36, I have a 1953 Chev 3/4 T. and have been looking for similar wheels as in your picture. Was wondering if you could offer any leads on where to find some reasonably priced steel wheels--? (You have a great truck--still working on mine as can afford it.) Thanks, T.K. | | | | | Joined: Jun 2006 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 91 | I just recieved today my new 8 lug steel wheels with .50 offset. These wheels fit my 50 3/4ton. Im gonna post pics and company info tonight, hopefully before the morning.
So if any one still needing modern 8 lug wheels with stock appearance look for my post bright and early. I should have it done by then. | | |
