3 members (dt235sd, Southerntruck, D B Cooper), 141 guests, and 2 robots.
Topics128,049
Posts1,055,675
#241807 10/05/2007 4:08 PM
I am converting my 1963 Chevrolet truck to front disc brake and leaving the drums in the rear. My question is can I use the original rear brake lines? I have been told that the proportioning valve has only one line to the rear and on for each side of the front brakes, is this true? Do I need to make new brake lines for the front? Another question please forgive me for asking so many. My rear brake plates do not have a slot to adjust the brake shoes, how do you do it?
#241808 10/05/2007 4:32 PM
Dennis,
The rear brakes have self adjusters, but if you need to adjust them, remove the wheel and drum and punch out the slot in the drum, you can then adjust the brakes through the slot. You can use the existing rear line for a disc conversion. I usually run new lines to the fronts from the proportioning valve.
Fred
#241809 10/06/2007 3:34 PM
I checked the rear brakes do NOT have self adjusters and the brake backing plates do NOT have a hole to punch-out. Can you install self adjusters on wheels that did not come with them?
#241810 10/06/2007 4:11 PM
63 trucks should have had self adjusters so yours has probably been changed. The drums may have been changed also if they don't have the knock outs. You can drill and file out a slot. I don't think that there would be a slot on the backing plates as the suspension components are in the way. You should be able to buy the springs and the self adjuster parts from a parts store.
Fred
#241811 10/06/2007 10:07 PM
My '63 does not have self-adjusters, and the info that I have found states that '64 is the first year for self-adjusting brakes. My drums do have slots to manually adjust the brakes, but I'm not sure if they are original. The link below is useful for info on '60 to '66 trucks.
http://www.60-66chevytrucks.info/
