4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
I need help adjusting the front brake on my 39 1/2. Driver side is fine. but the other side is draging too hard. The back brakes have an adjustment hole on the back side but I do not find this on the fronts. Do I have to take the hub off to adjust the fronts?
Welcome aboard K9
Later model Huck brakes have 2 slots on each backing plate, front and rear to adjust each shoe seperately. I believe the 39 originally
had one hole in each brake drum for access to adjust both shoes. Sometimes those drums were changed out to later model drums that did not have the access hole.
Ex Hall Monitor
Ex Hall Monitor
If it's the same as my 38 Rusty46 is correct. You'll find a hole through which you adjust the shoes. You may even be lucky enough that the original hole covers are still on them. If so they just pivot on the rivet to swing out of the way unless they're rusted in place.
No access holes on the back of the plate. How do I adjust them without having access holes?
Ex Hall Monitor
Ex Hall Monitor
Through the brake DRUM, not the backing plate. The drum is on the front. You'll find a hole maybe a half inch wide or slightly less which lines up with the adjusters. If they were changed out for later model drums & don't have the hole you'll have to get creative.
