| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I need help adjusting the front brake on my 39 1/2. Driver side is fine. but the other side is draging too hard. The back brakes have an adjustment hole on the back side but I do not find this on the fronts. Do I have to take the hub off to adjust the fronts? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Welcome aboard K9 Later model Huck brakes have 2 slots on each backing plate, front and rear to adjust each shoe seperately. I believe the 39 originally had one hole in each brake drum for access to adjust both shoes. Sometimes those drums were changed out to later model drums that did not have the access hole. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's the same as my 38 Rusty46 is correct. You'll find a hole through which you adjust the shoes. You may even be lucky enough that the original hole covers are still on them. If so they just pivot on the rivet to swing out of the way unless they're rusted in place.
| | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | No access holes on the back of the plate. How do I adjust them without having access holes? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Through the brake DRUM, not the backing plate. The drum is on the front. You'll find a hole maybe a half inch wide or slightly less which lines up with the adjusters. If they were changed out for later model drums & don't have the hole you'll have to get creative.
