1 members (Wayne67vert),
96
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | My '49 tie rod has a slight arc shape to it. Maybe 1/4-inch deflection in the middle. Did somebody before me hit a stump, or is the tie rod supposed to be shaped this way? Thanks! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My 49 is exactly the same and I also wondered. Apart from that everything else is fine, tracks well and doesn't ruin tires. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They should be perfectly sraight. They usually get bent from someone putting a jack under the axle & getting the rod with it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | norcal49er,
Adding to what Wrenchbender mentioned is the fact that they are tough and relatively flexible. This means if you are anal, you can pull the tie rod off and straighten it. A block of wood at each end, and the neighbors fat wife in the middle would probably do the trick.
Stuart | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Started this reply before breakfast, that's how long it takes me to upload. Anyway I see ya got the answers already, yep straight as an arrow. These are the blocks I made to straighten mine up in a hydraulic press. Just sneak up on it and don't try to get it all out the first time. http://rides.webshots.com/photo/2206648530098611668wexNYl Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Or just go out and buy an aftermarket one. Better quality than the original. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The TF trucks do the same thing, or at least mine did. BTW, it was like that when I bought it, I didn't bend it.
Bill Burmeister | | |
