1 members (carbking), 142 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#241375 09/27/2007 5:08 AM
My '49 tie rod has a slight arc shape to it. Maybe 1/4-inch deflection in the middle. Did somebody before me hit a stump, or is the tie rod supposed to be shaped this way? Thanks!
#241376 09/27/2007 5:43 AM
My 49 is exactly the same and I also wondered. Apart from that everything else is fine, tracks well and doesn't ruin tires.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#241377 09/27/2007 8:50 PM
Riding in the Passing Lane
They should be perfectly sraight. They usually get bent from someone putting a jack under the axle & getting the rod with it.
1972 Chevy c10 Cheyenne Super
#241378 09/27/2007 9:07 PM
norcal49er,
Adding to what Wrenchbender mentioned is the fact that they are tough and relatively flexible. This means if you are anal, you can pull the tie rod off and straighten it. A block of wood at each end, and the neighbors fat wife in the middle would probably do the trick.
Stuart
#241379 09/27/2007 10:56 PM
Started this reply before breakfast, that's how long it takes me to upload. Anyway I see ya got the answers already, yep straight as an arrow. These are the blocks I made to straighten mine up in a hydraulic press. Just sneak up on it and don't try to get it all out the first time. http://rides.webshots.com/photo/2206648530098611668wexNYl
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#241380 09/29/2007 2:21 AM
Or just go out and buy an aftermarket one. Better quality than the original.
#241381 09/29/2007 2:50 AM
The TF trucks do the same thing, or at least mine did. BTW, it was like that when I bought it, I didn't bend it.
Bill Burmeister
