5 members (MikeStone1953, Hawkman, fonz8261, 55shaker, Gdads51), 143 guests, and 3 robots.
Topics128,086
Posts1,056,099
Members48,434
#241316 09/26/2007 7:01 PM
Anyone have a tip for removing wing glass in an AD truck? I want the glass out without removing the frame from the door. Seals are hard, but look OK. I have tried gasoline applied along the glass to soften the tape - to no success. Any other suggestions. Thanks, BW
#241317 09/26/2007 11:47 PM
R.Wyant,
Clamp the wing glass with a large C-clamp that has a piece of wood under each 'foot'. Use a heat gun (hot air) to warm the window near the channel while your helper straddles the open door with their body, and pulls on the C-clamp. Be sure to hold your mouth right or the glass won't budge. wink
Stuart
#241318 09/27/2007 12:48 PM
Why do you want to remove the glass? If you just want to replace it and don't need a template why not use a hammer and break it?
~Jim
#241319 09/27/2007 2:29 PM
Anonymous
Unregistered
Anonymous
Unregistered
If you are not planning to reuse it - break it out carefully. If you are planning to reuse it - why take it out?
#241320 09/27/2007 3:42 PM
Good point on the 'breaking' method! I guess my thought was that if the glass was going to be removed and discarded, it would save 'picking and digging' if it could be pulled out in a single piece.
Stuart
#241321 09/27/2007 5:43 PM
atomarc - Used your method and got the wing glasses out in intact (needed a template). Thanks for the tip! The glasses were delaminating - pick up new glass tomorrow.
#241322 09/27/2007 6:26 PM
A template! Good for you...who would have thought of that. smile
Stuart
#241323 09/28/2007 2:56 AM
This is good to know...I have a wing glass that is still in an old door that I picked up for parts and I need to remove the glass and use it to replace the shattered one on my truck.
Thanx for the tip!
David wave
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
#241324 09/28/2007 12:34 PM
Soak in Gas or diesel kero and so on till old stuff gets soft.
#241325 09/28/2007 1:48 PM
I saw a neat trick on this one. The guy drilled out the pivot rivet, unscrewed the lower pivot, did the repair and reinstalled it with a stainless bolt instead of a rivet.
1951 1 Ton Completed
