2 members (Ole49GMC, Hush), 74 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Junior Member
Junior Member
1 Offline
Just wondering if anyone knows if you have to bang your fire wall back to fit a HEI distributor.I tried to install the cap and won't fit I also tried to look somthing up in the search section and had no luck.Thanks in adance for your help. Kyle
I have a 64 burb & a fleetside, the HEI fits in both w/no firewall mods, but is VERY close-gotta put the dizzy in first & then fit the cap, & no wire retainer on the top
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
H Online: Content
If there's even a little looseness in the motor mounts, you'll get really experienced at changing distributor caps. All it takes is a small amount of torque twist, and the cap will hit the body. If there's less than 1/2" of clearance with the cap installed, get out the BFH and give it a few good whacks before you install the distributor.
Junior Member
Junior Member
1 Offline
Yeah i put the dizzy in first without the cap but my distributor has a built on wire retainer I will invest in a different cap and try that thanks.
Accel, Mallory and MSD all make electronic distributors with smaller caps. The Accel unit uses a Mopar cap and the MSD unit uses a traditional GM cap. I have used both,but have now settled with a MSD ready to run unit. It has a magnetic pickup and has 1 degree of timing variation at 10000 rpm (not that you or I will be in that range with either of our engines)
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
I can stick my fingers behind mine-I noticed on the truck new cab mounts made a big difference in clearance.
Use the small diameter HEI with the remote coil - gives a little extra clearance without the BFH
H Online: Content
The small-cap newer HEI uses computer-controlled timing advance. There's no centrifugal, or vaccum advance available.
If you use an MSD ready to run distributor, you can use vacuum advance or not and the unit is packaged with different advance springs, so you taylor your advance curve. HEI is nice if you have the clearance, but sometimes in an effort to save a little coin you may make changes to your precious truck that you wish you hadn't (such as taking a hammer to the firewall).
Junior Member
Junior Member
1 Offline
That is one thing that I got to change is the cab mounts I will deffently look into that thanks for all the help.
