1 members (Oswald), 243 guests, and 2 robots.
Topics128,162
Posts1,056,942
Members48,458
Junior Member
Junior Member
I just bought a '60 Short Step and want to can the stock front suspension for a newer setup w/ disk brakes and rack and pinion. I just called a guy that was selling a mustang f suspension and he said that it would not work and that I needed a Mustang ll or Pinto f suspension. Does that sound right?? I'm looking for a direction here. I can do the fab., I just need to know were to start.
Scott out
Good thing you can do the fabrication. As far as know, that's the only thing that works with the 60-62 chassis. There is nothing bolt-in available. As far as what fits? Maybe someone else will chime in.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
'63-up front cradle assembly...I think all the way up into the '80s.
Do a search on here, 67-72chevytruck.com, and Jalopyjournal.com
It's a pretty common swap, and from what I've read, it's as simply as six bolts (and drilling holes for a couple of them)
I'm ALWAYS leary of any Mustang II swap...the control arms and spindles were designed for a very, very light car that made no power, and guys are putting them under '69 big block Camaros now. Plus, the geometry of the control arms was designed for a vehicle with a pretty narrow width.
I'd look at the later Chevy truck set-up, with a quick ratio power steering box.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Junior Member
Junior Member
Brad,
That's just what I was thinking, about the Mustang ll being narrow and too light. Thanks.
Scott out
Check out my webshots. I swapped a '79 onto my '50. Easy swap.
Robert C.
I'm a Genius in the making.
1950 3600
