| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 3 Junior Member | | Junior Member Joined: Sep 2007 Posts: 3 | I just bought a '60 Short Step and want to can the stock front suspension for a newer setup w/ disk brakes and rack and pinion. I just called a guy that was selling a mustang f suspension and he said that it would not work and that I needed a Mustang ll or Pinto f suspension. Does that sound right?? I'm looking for a direction here. I can do the fab., I just need to know were to start.
Scott out | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Good thing you can do the fabrication. As far as know, that's the only thing that works with the 60-62 chassis. There is nothing bolt-in available. As far as what fits? Maybe someone else will chime in. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | '63-up front cradle assembly...I think all the way up into the '80s. Do a search on here, 67-72chevytruck.com, and Jalopyjournal.com It's a pretty common swap, and from what I've read, it's as simply as six bolts (and drilling holes for a couple of them) I'm ALWAYS leary of any Mustang II swap...the control arms and spindles were designed for a very, very light car that made no power, and guys are putting them under '69 big block Camaros now. Plus, the geometry of the control arms was designed for a vehicle with a pretty narrow width.
I'd look at the later Chevy truck set-up, with a quick ratio power steering box.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Sep 2007 Posts: 3 Junior Member | | Junior Member Joined: Sep 2007 Posts: 3 | Brad, That's just what I was thinking, about the Mustang ll being narrow and too light. Thanks.
Scott out | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Check out my webshots. I swapped a '79 onto my '50. Easy swap.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
