| | | Forums66 Topics128,119 Posts1,056,648 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | would it be possible to set up a rack and pinon steering set up on a stock 58 tf axel?? a simple setup, not something that would require an engineer to layout. Mike Bourg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. Rack and pinion is best left for IFS. I've seen it done, but there's issues with the steering shaft having to have some way to flex and telescope with the suspesnsion motion, plus the extra weight on the axle itself. Rack and pinion systems are intended to solid mounted to the frame, ot the suspension components. That's why the oems never used it on a straight axle.
Bill Burmeister | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | that makes a lot of sense, thanks for the reply Mike Bourg | | |
