7 members (69 coupe, Gdads51, Phak1, jmoore, TUTS 59, 54farmtruck, 1955 1 Series),
91
Mod | | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I am hoping someone can help me. I have a perfectly working regulator in my 39 chevy. the problem is my stainless strap is broken. I cant seem to find just the strap. Has anyone fabricated one or know anyone that can fabricate one of these.
thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | I just installed my front crankout window, and crank last week. I would bring it to a reputable welding shop, they should be able to tig it together. The problem is, the weld effected zone may not hold up over the long haul. Look for a local metal fab shop. They can laser cut that in no time out of stainless. It may be cheaper and quicker to find a good used one on ebay.
Good luck | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | There is a guy in Central NY that has a few regulators for 41-46 if they're the same. I could ask if he has one. Dan | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | tig welding is not an option it seems to be missing a piece but thanks for the input. Dan if you could ask that would be appreciated greatly. thanks
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Mine was broken at the windshield end. I just squared off the end and made a different bracket. I guess the windshield does not open as far now by about 1/2" | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I believe 39 is the one year that is different from all of the others. 36-38 are the same, 39 stands on it's own and 40-46 are the same. They look basically the same, but some mount differently because of the dash configurations. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
