4 members (Still At It, 32Fordpuchoptop, treegrower, 1 invisible), 158 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#240278 09/04/2007 11:02 PM
Apprentice
Apprentice
I was trying to pull my tank out of my 52 GMC and forgot to disconnect the gas lines underneath. As soo as I removed my head from my ***, I saw a small suare piece of metal that had been soldered?? or something to the bottom of the tank, did I ruin this thing or can I JB weld this piece back on the tank. Any advice would be appreciated....Terry1218
Terry A. Dudash
1952 GMC 5-Window 1/2-Ton
#240279 09/04/2007 11:28 PM
Riding in the Passing Lane
It needs to go to a Radiator/gas tank shop & be soldered on. If the tank is full of rust now would be a good time to buy a new one. Nothing is worse than an old truck breaking down all the time because of a dirty gas tank.
1972 Chevy c10 Cheyenne Super
#240280 09/05/2007 2:57 PM
Bender said the Gosspil on this one ..you will not be able to GLUE it back on ..for safety sake at least ..
your lookin at a tank full a Gas behind you with somethin glued on ..NOT A GOOD DEAL
you will need to fix or replace in the right way.
Just my 2 cents .
Tim
1952 Chevy Shortbed
Photos in Photobucket
#240281 09/05/2007 6:52 PM
Get a new tank, the price is right...
~Jim
#240282 09/07/2007 1:18 AM
I agree. There is nothing worse than a bad tank. It smells, its dangerous, it causes constant problems from dirty fuel. If the lower outlet broke off that easy the tank needs to be replaced.
If you get a new one most come with a drain plug in the bottom. The outlet (i think by code) is part of the sending unit on top. I had to buy a new tank and a new sending unit but it was definitely worth the money.
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
#240283 09/09/2007 12:41 AM
I bought a new reproduction gas tank for my '54 GMC 100 pickup. It was an exact duplicate of the stock tank I took out and was easily installed and now I have no dirty gas problems. Well worth the $160.00 price tag.
