| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 33 Apprentice | | Apprentice Joined: Aug 2007 Posts: 33 | I was trying to pull my tank out of my 52 GMC and forgot to disconnect the gas lines underneath. As soo as I removed my head from my ***, I saw a small suare piece of metal that had been soldered?? or something to the bottom of the tank, did I ruin this thing or can I JB weld this piece back on the tank. Any advice would be appreciated....Terry1218 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It needs to go to a Radiator/gas tank shop & be soldered on. If the tank is full of rust now would be a good time to buy a new one. Nothing is worse than an old truck breaking down all the time because of a dirty gas tank. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Bender said the Gosspil on this one ..you will not be able to GLUE it back on ..for safety sake at least .. your lookin at a tank full a Gas behind you with somethin glued on ..NOT A GOOD DEAL you will need to fix or replace in the right way. Just my 2 cents . Tim | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Get a new tank, the price is right...
~Jim
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I agree. There is nothing worse than a bad tank. It smells, its dangerous, it causes constant problems from dirty fuel. If the lower outlet broke off that easy the tank needs to be replaced.
If you get a new one most come with a drain plug in the bottom. The outlet (i think by code) is part of the sending unit on top. I had to buy a new tank and a new sending unit but it was definitely worth the money. Rich | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I bought a new reproduction gas tank for my '54 GMC 100 pickup. It was an exact duplicate of the stock tank I took out and was easily installed and now I have no dirty gas problems. Well worth the $160.00 price tag. | | |
