1 members (Millenimech),
118
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | My '42 1/2 ton rides really hard...rear springs are very tight. Just wondering what others have done to soften the ride. Has anyone removed leaves? How many? Which ones? | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Yes you can remove some, start with the smaller ones, tow or three of them should help. You can't haul as much weight with leafs removed!
You can also grind each leaf smooth so they ride on each other easyer, or add the teflon poly strips to each leaf. I bought mine from Speedway in Lincoln Ne. It worked great, I went back and added it to the front leafs. The truck is much quieter on rough roads and way smoother riding. Most any speedshop or street rod parts vender lists it in 20 foot lengths. My 37 used 3 roles of it to do four springs. Joe | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Joe H...thanks for the help. How much, if any, did you lower your rear stance when you took out the leaves? Did you modify your front springs as well? I don't plan to do any major hauling with this truck. | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | I added aluminum blocks the same thickness as the springs I removed, about 1/2". I like the look of stock heigth, not sure how much it would have lowered it. I did remove some leafs from the front as well, three I think, from the bottom. Joe | | |
