| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | OK....now you have done it confused me yet again and that is easy to do.....OK, coolant drain plug for engine on driverside lower corner of block.. open and flush engine/radiator.. install new hoses and new thermo...add coolant and make sure heater core valve is open...fill with coolant and let her warm up and keep filling her.....where is the air...the air is pushed out via the top of the radiator says my cousin the mechanic. I want to drill small hole in thermo but Mr. mechanic says NO not nessasary! I want to keep truck slight up hill while filling... Mr. mechanic says no not necessary......I GIVE UP...what is the correct coolant filling procedure step- by- step ? I trust you guys more than Mr.(my cousin) the Mechanic....t/c steve :confused_smile: :mad: | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Steve don't be confused,be deffused !! The radiator should be your highest point.As you run the engine and the water pump circulates the coolant, it should bring all of the air to the top of the radiator.As a side note,Oldsmobile used a thermostat that had a small hole in it for years. May all your air disseminate !
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Well, it can't be that easy....if the thermo is working why would you need a hole in it ask my cousin Mr. Mechanic...he has me there. I need a good answer gtow69....T/C Steve | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
Under the perfect scenario, a large air bubble would find the highest point in the engine to roost...this would be immediately under the thermostat. The little thermo-motor needs direct contact with heated coolant to react properly.
The small hole that is drilled in the flange allows this bubble to travel through to the tank, along with a limited flow of coolant, but insures the thermostat is surrounded by coolant.
This is how I envision it working, but between the Zanax and the Cutty Sark, I might be in Belfed's fog zone! :confused_smile:
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The hole in the therm. is agood idea. I usually pull the heater hose off right under the therm & fill it till it comes out of there & shove it back on, then continue filling. Running the engine till the therm. opens & then filling is not a good idea especially on the newer engines. A dry hot spot can crack or warp a head. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Someone once suggested wedging an aspirin in the stat to help purge the air. Of course I read that after I had already drilled a hole in mine. Stovebolts are notorious for trapping air in the head.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Why do you think the factory installed a steam vent in the 261 block and head? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If all else fails you can take the aspirin with a glass of water.
~Jim
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | And if things are still hopeless, that another aspirin with a glass of coolant! Stuart | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | OK guys keep your day jobs the comedy act still needs work.(:>)... I will drill a hole in the stat and fill the hose below the stat. What else can I do to insure a good job and a happy 235. What would be the best type of coolant/mixture for this engine and will a 165 degree stat do the job with a four pound cap on a 55- 57 235 engine....THANKS, Steve | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 50/50 regular old green stuff. Don't use the pink/orange or the gold, those are for late models and can damage the pump. The "mix with anything" will be fine, too. If you can find it, get the full strength stuff and cut it yourself. I find that the "pre-mix" is a little weak for my tastes. Side note, I didn't drill a releif hole in my theremostat, and have had no issues with air in the block/head, however, it won't hurt anything to do so. There are even thermostats on the market that have a hole already in them. one more thing-pour it slow. Don't rush it, just go nuce and easy. That will help allow the air to purge out. If you listen to it, you should be able to hear the air comming out at the filler neck.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | THANKS BILL...where might I go to purchase one of these stats with a pre-made hole and what do I ask for? Is 165 a good number.. it gets a little warm where we are in the summer 88-98 and gets to 32 to 48 average in winter...T/C, Steve  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 165 is waht they came with factory, I'm running one myself with no overheating issues. I'll have to check on who actually make those thermostats, but i know i've seen them, maybe at Napa?
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Bill, when/if you find out where they can be purchased please let us know. There are several owners that have never heard of the hole/vent on a bolt stat. We are all interested...we are still learning about these bolts. Thanks and T/C Steve | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm not having luck finding them online, I can't remember who makes them, but i know I've seen them. Next time I'm at the flaps or the speed shop, I'll look into it.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can just loosen the coolant temp sensor to let the air out of the head, but the hole in the stat is nice if you suddenly suck air and don't realize it.
A lot of times you can get away without the hole if the stat doesn't sit tightly in the housing- it might leak a bit.
The BMW I used to have had a bleed screw on the thermostat housing that worked nice.
The 261 doesn't need a hole in the thermostat if it has a bypass thermostat, the bypass takes care of the air burp.
The only thermostat I've ever seen that had a factory burp hole was a Robertshaw thermostat, and I haven't seen a new one anywhere, the only ones I can ever find are Stant.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hi Steve; I had to replace a faulty thermo. in ol' green just last week. I got a 185 from NAPA but I'd go with a 165 since your weather tends to be on the warm side. I drilled a 1/8" hole in the flat spot of the thermo. Took all of 15 seconds if you don't count the time lost trying to locate the drill bit in what has to be the world's messiest shop. (I cleaned it up since then, now I probably won't be able to find anything)
She burped herself (the truck) - no problems at all. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | the reason you want a couple holes drilled in the edge of your thermastate is a good one it will save your engine when the thremastate sticks trust me it does happen i wont run one without a few holes in the edge after overheating two engines over the years one 68 chevy one new boat with a chevy 4 banger that ran just hot enuff to burn the head up after a year the guage never went over 190 it always ran just a little hot runs perfect now and yes the therm. is drilled | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 32fire2 Question: What size hole are we talking about? If it would save overheating when the thermostat locks up I would think it needed to be 1/4".
~Jim
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The hole in the thermostat is great for removing air from the system however if you want to prevent damage when the thermostat fails get one of the new ones that fail in the open not closed position. These things are a life and an engine saver.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | 1/8" or 3/16" will work fine. I drilled mine based upon advice received from a lot of 'Bolters. No problems. Think the original early thermostats were two stage and were manufactured by Harrison who also made radiators. Don't know exactly how they worked though. Mine's a Stant. http://community.webshots.com/user/geezer | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I'm back t/c Steve.Got no GOOD answers, just ones that seem to work.The hole in the thermostat will purge the air out even when the stat is closed (as in when it sits overnight).Usually you can hear air in a system at the heater core.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | haven't had a chance to check on that thermostat yet, I know someone still makes them, might have to look in some of my catalogs. If you're concerned about the 'stat sticking shut, you might consider the Motor-Rad theremostat. They're not supposed to stick in the closed position. One more suggestion, not really on purging, but I would suggest a bottle of Red Lines Water Wetter. I use it in mine, and it does make a difference in the effficiency of the coolant.
