1 members (TooMany2count),
119
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | Firstofall, does anyone know what temperatures are represented by the C --- H temp gauge? I assume the needle should ride halfway between the C & H, but mine is reaching nearly over to the H. Granted, it has been around 100 outside the past couple of weeks. I'm running an original triple-core radiator with a 13 psi cap. When I park, I usually lose a hand-sized puddle of coolant out the overflow hose. How do I know if the system should be burped? Also, someone told me to go to a 16 psi cap, does this sound better? Advice is mightily appreciated. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These dash gauges are just indicators. They can very a lot. Does the gauge go right up to the temp. & stay there all the time or does it run cooler & go up when it gets real hot out. A lazor thermometer would tell you what is happening or you can take off the cap & put a thermeter in the coolant & see how hot it gets & compare it with the gauge. Sometimes a new thermostat is defective. Iwould use a 180. I would not go to a higher pressure cap then that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | It reads cool at startup, then gradually works up to that high reading, which gives me confidence in its accuracy. Also, I forgot to mention the engine's a 350. I'm going over the thermostat right now, would you still recommend a 180? | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I would recommend a slightly lower thermostat. The temp is when the thermostat opens and water begins to flow from the engine to the radiator. On a hot day (all summer), do you really want the water hitting 180 before flowing? I think the radiator and cooling system has to play catch-up at that point. I had a 160-degree in the 283 I just pulled out. In the high 90s, the engine would stay nice and cool. I also installed a 7-blade fan and a fan clutch. I didn't get the fan shroud on yet...found out I need to modify it.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | It sounds like a stopped up radiator to me. | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | My buddy also says the radiator could be clogged. I checked the thermostat & it seems to open up at the right time, and running it with the cap off I could see circulation in the top of the radiator, but i didn't know how much circulation was enough. I flushed the rad before i put it in and it seem to flow pretty freely. Could a slight clog be the problem? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | It really won't be clogged like a drain, but simply coated inside w/calcium or whatever deposits, this insulates the tubes inside & keeps them from radiating heat. Drain a little coolant out & look at the tubes for deposits. My 79 would run hot, the rad was rodded out 10+ yrs ago & had no leaks, it is 3 ft tall & 2 ft wide w/a 4 row core, good stat & fan clutch. I really just couldn't see it running hot w/that big of a radiator but it did. I really didn't want to buy a new rad($500+), but it solved the problem. Now it runs on the cool side. | | |
