2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Firstofall, does anyone know what temperatures are represented by the C --- H temp gauge? I assume the needle should ride halfway between the C & H, but mine is reaching nearly over to the H. Granted, it has been around 100 outside the past couple of weeks. I'm running an original triple-core radiator with a 13 psi cap. When I park, I usually lose a hand-sized puddle of coolant out the overflow hose. How do I know if the system should be burped? Also, someone told me to go to a 16 psi cap, does this sound better? Advice is mightily appreciated.
Riding in the Passing Lane
These dash gauges are just indicators. They can very a lot. Does the gauge go right up to the temp. & stay there all the time or does it run cooler & go up when it gets real hot out. A lazor thermometer would tell you what is happening or you can take off the cap & put a thermeter in the coolant & see how hot it gets & compare it with the gauge. Sometimes a new thermostat is defective. Iwould use a 180. I would not go to a higher pressure cap then that.
1972 Chevy c10 Cheyenne Super
It reads cool at startup, then gradually works up to that high reading, which gives me confidence in its accuracy. Also, I forgot to mention the engine's a 350. I'm going over the thermostat right now, would you still recommend a 180?
I would recommend a slightly lower thermostat. The temp is when the thermostat opens and water begins to flow from the engine to the radiator. On a hot day (all summer), do you really want the water hitting 180 before flowing? I think the radiator and cooling system has to play catch-up at that point. I had a 160-degree in the 283 I just pulled out. In the high 90s, the engine would stay nice and cool.
I also installed a 7-blade fan and a fan clutch. I didn't get the fan shroud on yet...found out I need to modify it.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
It sounds like a stopped up radiator to me.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
My buddy also says the radiator could be clogged. I checked the thermostat & it seems to open up at the right time, and running it with the cap off I could see circulation in the top of the radiator, but i didn't know how much circulation was enough. I flushed the rad before i put it in and it seem to flow pretty freely. Could a slight clog be the problem?
It really won't be clogged like a drain, but simply coated inside w/calcium or whatever deposits, this insulates the tubes inside & keeps them from radiating heat. Drain a little coolant out & look at the tubes for deposits. My 79 would run hot, the rad was rodded out 10+ yrs ago & had no leaks, it is 3 ft tall & 2 ft wide w/a 4 row core, good stat & fan clutch. I really just couldn't see it running hot w/that big of a radiator but it did. I really didn't want to buy a new rad($500+), but it solved the problem. Now it runs on the cool side.
