4 members (Gdads51, 3800GUY, TUTS 59, 68ironhead), 81 guests, and 1 robot.
Topics128,118
Posts1,056,302
Members48,439
#240053 08/30/2007 8:21 PM
Junior Member
Junior Member
Just acquired a very nice running 42.....but is the 'Armstrong' method of steering standard with this truck? King pins have been replaced, tires are new and inflated but at slow speeds really hard to steer, road speeds, gentle turns OK.....any advice?
#240054 08/30/2007 8:29 PM
Paul Schwengel,
Welcome to the Stovebolt. I don't have one of these rigs so the SOP just might be big biceps. My first thought would be a worn out steering box.
If someone just did the king pins, then they probably looked at, or adjusted the box! Did you check it for lube and does it have any free play. If adjusted incorrectly, in an effort to tighten it up, it could be binding as it comes across 'center'.
Stuart
#240055 08/30/2007 9:08 PM
Riding in the Passing Lane
Make shure the kingpins are well greased & all the fittings take grease. If everything is good then it,s just a matter of armstrong.
1972 Chevy c10 Cheyenne Super
#240056 08/30/2007 10:16 PM
Anything below 5 mph is going to be armstrong. Another thing to look at is the tie rod ends and drag link. If the ball is no longer perfectly round and the cups are over tightened this can make the steering real stiff going off center left or right.
#240057 08/30/2007 11:22 PM
It really is armstrong. My 42 does the same thing. I think we are used to powering steering.
The crew that works on the \'42 --Sara, Hannah and Abby
#240058 08/31/2007 12:18 AM
Come on now... it's good for you! It'll probably keep the lady from driving it too!
#240059 08/31/2007 12:56 AM
Great, ain't it?... When trucks were trucks and men were men?... Not trying to be sarcastic, but thats pretty much it! It's not a one handed affair, unless you have a brody knob. Even then you better be rolling.
If your concerned, jack the front end up and try the full range left and right with both tires off the ground. Tire inflation is a big factor. If your really concerned, I think the service manual gives a fish scale pull weight at the steering wheel with the pitman arm disconnected.
1941 AK named "PETEY" my buddy.
#240060 08/31/2007 12:58 AM
Oh!,... Please excuse me. WELCOME!
#240061 08/31/2007 1:03 AM
Junior Member
Junior Member
Thank you all!!!!!!!! Will start working out again, especially biceps.....
#240062 08/31/2007 2:27 AM
My 41 chevy isn't bad. It takes a little muscle but as long as the wheels are turning little effort is needed until it is loaded. Besides powersteering is overrated. America needs to loose a few pounds and what better way can you do that but by driving a stovebolt.
You think that is tough try a M class tractor with front loader no power steering and max load. Even underway it can take two people to crank that wheel.
#240063 08/31/2007 3:41 AM
Former Workshop Owner
I suspect that something, or maybe many things are not quite right. It could be an accumulation of everything already mentioned, and more.
Do you have a stock steering wheel, or a smaller one? A smaller diameter wheel will decrease your leverage, and more muscle will be needed.
The tires are new, but are they the standard diameter and width, or are they smaller and wider? A tall narrow tire will turn easier than a low profile fat one.
What about the bushing on the steering shaft? If that is badly worn, it might be increasing drag (resistance). Just a theory, but when you are applying all that extra might, you are actually pushing, or pulling the steering shaft against the bearing or (bushing).
And, as already mentioned above, lubrication is extremely important.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#240064 08/31/2007 9:12 PM
Junior Member
Junior Member
Thanks, will check the bushing issue, everything else checks out, steering wheel(stock) tires per owners/shop manual.
#240065 09/01/2007 2:15 PM
Reminds me of trying to teach my wife how to drive our ’41 ¾ ton. As she backed it straight out of the garage then attempted to turn She complained that the steering wheel would not move. I simply replied “let out the clutch”. At first she couldn’t make the connection between the clutch and the steering (she does drive a stick shift) I finally explained “no power steering, you pretty much have to be moving to turn the wheel”.
Oh yes welcome aboard. I would go with all the advice above. You might even try jacking both front wheels off of the ground to see if all the steering components are free
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
