4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#239862 08/27/2007 5:52 AM
hello all,Im for the land of the froozen north and need to know if the stock heater will keep me from freezing at 30 below.the cab is a 52 chevy 1.5 ton, it will be setting on a 77 4x4 daully frame. If so will need to find a complete heater unit,and if not what is avaible? any thoughts would be of great help.THANK YOU
#239863 08/27/2007 7:23 AM
We have at least 2 other guys from Homer. Hope they come around soon to tell you their experience. In the mean time, welcome to the stovebolt pages.
#239864 08/28/2007 12:23 AM
Why would anyone be out at 30 below??? :confused: ohwell
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#239865 08/28/2007 12:27 AM
Because he has to work during the summer!
But my answer to your question is, probably not.
#239866 08/28/2007 12:37 AM
Ex Hall Monitor
Ex Hall Monitor
I've had my 38 out at 30º above & had to close the doors on the heater to keep from running me out with the fan running as slow as it'll go. Does that extrapolate to comfort at 30º below???? ohwell You can find heaters on eBay. I bought my restored heater from Roger Kaster ([email protected]). If the addy is still good he may be able to help you out.
#239867 08/28/2007 12:57 AM
I believe the key to this would be the seal of the cab and insulation. If you have wind coming through holes and little insulation in those temps I don't think the heater can compete. However, these cabs can be sealed up tight and relatively easily insulated. At that point you have a fan running through 180 degree heater core and the air does come out hot in these trucks. As you may know, there are few types of heaters for these trucks. While the deluxe fresh air is more sought after, the recirculating heater might be better for cold climes by not taking in the cold fresh air. Good luck.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#239868 08/28/2007 1:34 AM
Red dot, center of chest ...
I have a complete deluxe heater. You can see my ad here
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#239869 08/28/2007 3:13 AM
The key would be to insulate your truck and seal off the controls that go through the floor. Weather strips and window seals to keep the wind out. A partition between the seat and the -30 temp fuel tank would also help,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#239870 08/28/2007 4:29 AM
Be prepared is the motto of the Boy Scouts of America and a smart thing to be. I would always carry an old coffee can full of pea gravel and a can of kerosene when traveling in winter in the old step vans in East Texas. It would sometimes go below 0 and with all the cracks and holes the heater couldn't keep up. I would pour the kerosene in the coffee can (the gravel kept it from sloshing out) and light it up. That worked well in emergencies.
I know someone here will freak out over the toxic fumes but one must do what one must do. cool
~Jim
