Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TUTS 59, Hambone, dunfire, Otto Skorzeny, baldeagle, Rusty Heaps), 41 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#239322 08/19/2007 1:34 PM
I'm goimg to use an automatic trans in my 59, did they ever put the shifter linkage on the column, or did they never use the automatics back then. I'm sure they did, but I can't seem to find one. Any help? Thanks, Mike
#239323 08/19/2007 2:11 PM
yes, an optional hydramatic was available, and used a column mounted shifter - will be shown in the factory assembly manual
#239324 08/19/2007 3:26 PM
The factory columns for the auto are pretty rare. Here is what many do if they keep the factory column. Take the top cover off the shifter transmission (box at bottom of column), wipe grease off, have someone hold the shifter handle up in the neutral slot like they were going to put it in low or reverse, dot with weld to hold it there. Now put the trans in park, hold the shift lever where you want it to be when in park and measure the distance from the hole in the shifter lever to the hole in the lever on the transmission. Make a shifter rod to fit. Some people just tie the 2nd and high lever off to one side which works but isn't as tidy looking. Here is a photo of this setup including a home made neutral safety switch and bracket that lets it start in park only. Some rig an indicator up but after driving very little you will feel the distance from park to drive and just do it without thinking. http://s32.photobucket.com/albums/d41/coilover/
Evan
#239325 08/19/2007 3:29 PM
Forgot to tell you to scroll down the page to the very first picture.
Evan
