2 members (Peggy M, Gray_Ghost),
184
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I want to replace the shocks on my 1951 Chevy 3604. These shocks have to be older than me (33). I started on the rear and after getting the nut off the bottom, I can't remove the bolt that runs through it.  I posted a couple of pictures on my webshots (pg. 10). I thought the bolt was supposed to slide out, but it doesn't budge. I used a large screw driver and pried upwards on the shock (which moves rather freely because there are barely any bushing left) and still nothing. The bolt does turn freely in both directions. What am I doing wrong or do I need to use some brute force? :confused: | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wada,
I'm in agreement with Brian...a BOBFH! I think the rubber bushing might have had a metal ferrule inserted into it and it and this is rusted to the bolt. Its diameter is greater than the hole size, hence the 'no go'.
Take a big hammer, and when the bolt is looking the other way, blast it. It's possible that you won't get it out and will have to resort to some type of saw or wheel to cut both ends of the bolt.
Stuart | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Thanks for the advise guys. I appreciate it. Jeff | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just changed my original black Delco Products shocks this summer (1950, 3604) and they're correct, the bolt is simply rusted to the bushing. An absolute must for removing shocks in my book is an impact wrench. After a good soaking overnight hit them with the impact turned up all the way. This is sometimes the only way to get the upper nuts off. For the upper rears I drill an access hole with an 1 1/2” hole saw and put a flush plug in it afterwards. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I soaked mine for a couple days before removal with liquid wrench on the bottom. I used a long taper punch to drive the bolt out when I had the nut off. As the other posts have stated it all falls apart as you dissasemble it. on the top I just cut the nut off with a grinder since my bed is off for restoration it sure makes this job a lot easier. | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i used alot of heat to get my shocks off. dont melt the threads you run the risk of melting stuff together just get the shock almost red hot the drive the bolt out. course i like useing heat to take things apart might be a bad idea
gotta love old trucks
| | | | | Joined: Nov 2006 Posts: 5 New Guy | | New Guy Joined: Nov 2006 Posts: 5 | I just did mine on my 64. soaked them down with PB Blaster the day before, made it easier.
You can love your truck, but it'll never love you back.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Heat & cutting torch work good but the lower part of the shock is filled with oil. They can & will explode. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Thanks again guys for all of the advise. I hope I can get them off this weekend. Jeff | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Be VERY careful if you use heat. I used to work with a guy who had one explode on him, and the result ain't pretty. | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I won't be using heat. "Danger" is NOT my middle name, except when I've got her out on the road! Jeff | | |
