| | | Forums66 Topics128,196 Posts1,057,390 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23909 11/19/2003 1:34 AM | Joined: Nov 2003 Posts: 8 Junior Member | | Junior Member Joined: Nov 2003 Posts: 8 | Are the engine backplates the same for the 230 ,235, 250 & 292 cu in engines? I guess another way of asking this question would be : will all of these engines bolt up to the same bellhousing ? I am new at this and trying to sort out some things on a swap into a non-Chevy truck . Thanks in advance for help from the experts. | | |
#23910 11/19/2003 3:33 AM | Joined: Mar 2003 Posts: 23 Junior Member | | Junior Member Joined: Mar 2003 Posts: 23 | Nobody else has replied yet, so I'll help out. The 235 & 216 have some bolts that you have to drop the clutch & flywheel to get too. I believe the other 6's have all exterior bolts on the bellhousing. But, will the trannys interchange with the bellhousings? I haven't measured but the holes look like they will line up. Somebody else will know for sure. Good luck with the project.
Scooter
I am a total control freak. I shift for myself. No auto's!
1948 1 ton 5 window w/235 1951 1.5 ton dump w/235 1966 3/4 fleetside w/283 1962 Bel Air 235 w/OD & one rusty,beat up,240K mile '82 Chevy 3/4 ton
#23911 11/19/2003 3:47 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Shep: Are the engine backplates the same for the 230 ,235, 250 & 292 cu in engines? Unfortunately no. The 235 is an earlier motor and is different. The 230, 250 and 292 I believe are all the same as Chevy V-8s. If I'm wrong someone will correct me, and I'm absolutely sure of that.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#23912 11/19/2003 4:54 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Don't know what you're trying to wed, but this site might help. Novak Jeep site Old sub is right on the bell housing mounts being the same between the late six and the small block.
Fred 52 3600 69 C-10
#23913 11/19/2003 8:18 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Bellhousings will not mate up between engine series. Transmissions, however, will, up to a point. The bolt pattern is the same but some transmissions and bellhousings have bigger center holes than others.
#23914 11/19/2003 8:23 AM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | If you use a 250 on a pre 1954 you wil need to change the trany support to a 54-? The bell house changed. | | |
