| | | Forums66 Topics128,281 Posts1,058,479 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23854 02/10/2005 9:11 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Will this carb work on a chevy 307? Thanx in advance Dano
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#23855 02/11/2005 2:02 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I'm not exactly sure what a 9503 carb is. I think it's an AFB type carb...at least according to what Carter's rebuild kits fit.
Anyway, it'll fit if you have a squarebore manifold like an Edelbrock 2101. Usually the stock carb on a 307 would be a Quadrajet and it's a spreadbore (if it has a 4-barrel carb on it already.) If it has a q-jet, you'll need an adapter or a different manifold and hookin up the fuel line and carb linkage will require a little engineering. But it ain't hard to do.
I run a Carter 625 cfm AFB carb (I don't know the model number...it's an electric choke) on my 292 I6 and love it.
hth, | | |
