2 members (Simon1954, KingG),
56
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23832 02/13/2004 1:36 AM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | hey guy been awile I have a chance at a 72 chevy fleetside the guy says the engine is a 327 my question is : is there anyway I can identify to be sure this is what the engine is sure would look nice under the hood of my 52 I'm trying to get the truck for oldest son and he will prob change engine anyway but if it is a 327 I wouldn't want it to slip away thanks | | |
#23833 02/13/2004 1:56 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If the motor is original its not a 327. There should be a number stamped on the block just in front of the passenger side head. If you can find and read that number its possible to look it up and determine what the motor originally. I've found these codes on the web before, but don't recall where. Otherwise you're stuck looking at casting numbers, which should narrow it down too. Casting numbers can be found at http://www.mortec.com/castnum.htm.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#23834 02/13/2004 6:34 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Go to Mortec. THe 72 came with either the 350 or 307, 327 was discontinued in trucks in 68. Not saying it can't be a 327, but check. If it is a 68 327, grab it, they used the larger mains for the 350 that year.
Fred 52 3600 69 C-10
