4 members (klhansen, Eisenholtz, homer52, Otto Skorzeny), 69 guests, and 4 robots.
Topics128,023
Posts1,055,371
Members48,420
#23832 02/13/2004 1:36 AM
hey guy been awile I have a chance at a 72 chevy fleetside the guy says the engine is a 327 my question is : is there anyway I can identify to be sure this is what the engine is sure would look nice under the hood of my 52 I'm trying to get the truck for oldest son and he will prob change engine anyway but if it is a 327 I wouldn't want it to slip away thanks
#23833 02/13/2004 1:56 AM
If the motor is original its not a 327.
There should be a number stamped on the block just in front of the passenger side head. If you can find and read that number its possible to look it up and determine what the motor originally. I've found these codes on the web before, but don't recall where.
Otherwise you're stuck looking at casting numbers, which should narrow it down too. Casting numbers can be found at http://www.mortec.com/castnum.htm.
#23834 02/13/2004 6:34 PM
Go to Mortec. THe 72 came with either the 350 or 307, 327 was discontinued in trucks in 68. Not saying it can't be a 327, but check. If it is a 68 327, grab it, they used the larger mains for the 350 that year.
Fred
52 3600
69 C-10
