0 members (), 125 guests, and 6 robots.
Topics128,186
Posts1,057,211
Members48,465
Junior Member
Junior Member
2 Offline
When I purchased my truck, I didn't know it had 2 different wheel lug set ups on it. The fronts are the original 8 lug 3/4 ton, and the rears are 1/2 ton 5 lug as the rear differential has been changed.
Now I will need to make a change. I think the best option would be to change out the complete front spindle and brake set up to match the rear bolt pattern. What do you think? Is there a huge difference in the 1/2 and 3/4 ton front ends?
What will I all need to complete this? I really don't want to go to disc brakes at this time as I for sure want to use stock 1964 rims and hub caps. Does anyone have all these parts?
Please click to see webshots of the front and rear.
Bruce in Las Vegas
http://community.webshots.com/user/2X1964
Junior Member
Junior Member
2 Offline
Oh! I forgot to add that the truck does have power brakes.
Thanks.
Just my own opinion here, I'd find an 8 lug rear to put back into it, perhaps a later 14 bolt from a '73-'87. Better chance of getting a 3.73 or 4.10 gear that way. You might be able to swap out the spindles, the upper balljoint can be changed to the 1/2 ton part for sure. I'm not to certain about the lower. The book shows a different part #, might be a larger part than 1/2 ton. You might have to swap to a 1/2 ton lower control arm to do the conversion. Either way, you're going to have to get matching rims.
Bill Burmeister
It really depends on what you want your ride to be when finished. You could match the rear with a Mustang II front suspension. That would improve your steering and suspension. I'm certain others will drop by with their 2 cents.
What ever you do I know you will have fun.
~Jim
Yeah, the easiest thing to do would be put a newer (1980's are plentiful at the boneyards) 8 lug rear in.
You can't just change out the spindles and brake stuff. You'd have to change out the A arms and ball joints. To match a 5 lug, I think you'd be looking at disc brakes. And using a stock '64 rim would require 6 lug (or 8 for C20).
Save yourself a lot of time and hassle and pick up a newer 8 lug rear.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
If it were me, I would install a-arms/spindles/etc from a 71-up C10 on the front & have 5 lug all around & disc brakes, 1/2 ton stuff. Use 71-up 5 lug wheels & 64 hubcaps, no one would know.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Junior Member
Junior Member
2 Offline
Thank you guys. I am going to take the next few days and see what I can find around Las Vegas for
a newer 1/2 ton truck for parts.
I also am looking to find a power steering set-up. I had forgotten how it was when we didn't have all the modern conveniences.
